gas flowing out of carb while tecumseh 5hp is running??? Help! - HobbyTalk
post #1 of 6 (permalink) Old 11-17-2006, 12:48 PM Thread Starter
Member
I just bought a Manco 2 seater go kart. It has a 5 hp sideshaft tecumseh engine. The engine starts on the first or second pull, but when you put gas in the tank, it just runs out the side of the carb slowly. Also when it is running, it runs out of the carb. So it can pretty much just idle and not that smoothly at that. Any help will be most appreciated. Ask any questions if there is any thing else you would like to know. Thanks.
Justin
oncewaslost1982 is offline
Sponsored Links
Advertisement
post #2 of 6 (permalink) Old 11-17-2006, 01:27 PM
Member
bsman's Avatar
could be a bad gasket and/or float is either stuck or filled with gas.
bsman is offline
post #3 of 6 (permalink) Old 11-17-2006, 02:14 PM
Top Dog
30yearTech's Avatar
Agree with bsman, but also check the fuel inlet elbow where the fuel line attaches. The plastic nipple sometimes cracks and leaks there.
30yearTech is offline
post #4 of 6 (permalink) Old 11-19-2006, 09:47 AM
Member
I had a similar problem on a Tecuseh I was working on. I took the carb apart and realized that the float (donut style) had a pin sized hole in it. I bought a $25 carb rebuild kit and solved the problem. It sounds like you're having float problems. Hope this helps.
Hooper is offline
post #5 of 6 (permalink) Old 11-20-2006, 12:32 PM Thread Starter
Member
ok I took the bowl off of the carb and pulled the float and needle assembly out and it was all gummed up. I thoroughly cleaned the carb with carb cleaner and cleaned off the float, got it all put back together, pull started it , with a little starting fluid in the carb and it fired up, but i broke the pull string with that last pull, and the switch was off so it didnt stay running, my bad. So now i cannot do anything with it until i replace that pull string. HOw difficult is it as far as what all has to come off the motor in order to change that pull string? thanks for any more help.
Justin
post #6 of 6 (permalink) Old 11-20-2006, 01:22 PM
Top Dog
30yearTech's Avatar
Depending on your specific model engine, the starter may come off from the blower housing with just 2 screws, or you may have to remove the blower housing from the engine to get to it. In either case it is not that difficult to do.
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
