Removing an impeller from an MTD Chipper Shredder - HobbyTalk
post #1 of 5 (permalink) Old 06-11-2006, 03:18 PM Thread Starter
New Member
I am trying to remove the impeller from my MTD chipper shredder model # 244-648B000 with a Tecumsah 8 hp engine. I have everything removed but the impeller. I feel like Egger trying to open the box of diamonds in Men in Black. I'm assuming this is a keyed crankshaft. I've tried everything I can think of. Any help would be appreciated.
phoneman is offline
Sponsored Links
Advertisement
post #2 of 5 (permalink) Old 06-12-2006, 11:34 AM
Member
Are there any puller bolt holes in the impeller? If not, a good dose of WD-40 and a rubber hammer might shift it.
Munkey is offline
post #3 of 5 (permalink) Old 06-18-2006, 07:30 AM Thread Starter
New Member
I've tried a pull with no luck....I'll try the WD-40 Thanks
phoneman is offline
post #4 of 5 (permalink) Old 06-19-2006, 09:00 PM
Member
Thumbs up Try candle wax to loosen
Get a propane torch heat up impeller not shaft. Take a candle made of parafin wax and it will get sucked inside the hole when held near shaft.Then use a steel hammer hit in both directions.Have fun watch the fingers!
Rpeters123 is offline
post #5 of 5 (permalink) Old 06-20-2006, 01:04 AM
HobbyTalk Pro
bugman's Avatar
Or PB blaster....... wd-40 wasn't cut out to do anything more then what it was actually made for.... a water displacer (WD)
bugman is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
