Poulan Pro BVM200 Blower, Will Not keep running - HobbyTalk
Reply
post #1 of 19 (permalink) Old 10-27-2012, 11:11 AM Thread Starter
Member
I have a Poulan Pro BVM200 blower that I got at a yard sale. The seller said it would not run, and it wouldn't. I bought it. I checked the plug and it was clean. I checked the primer bulb and it would not fill with fuel. I checked the fuel tank and found that the smaller tube in the tank was totally destroyed. I replaced the bad smaller tube and blew out the larger tube. The primer bulb now fills with fuel. I was able to get the motor started a number of times but after about 10 seconds it stops. I have read that there is a fuel filter somewhere but have not been able to find it. I think the filter may be blocked. Any guidance on the filter or what may also be wrong that causes to motor to stop after 20 seconds? Any help will be appreciated.
brennanspapa is offline
Sponsored Links
Advertisement
post #2 of 19 (permalink) Old 10-27-2012, 01:05 PM
Elder Statesman
Hello and Welcome to Hobby Talk.First the bad news,these blowers are pretty much considered throw aways.
The screws that hold the cylinder to the crank case and the screws holding the carb to the intake manifold have a tendency to loosen from vibration.Once air is drawn in,the fuel mixture gets leaned out causing the piston and cylinder wall to score from lack of lubrication.If you have a compression gage,see if you have 100psi or very close to it.You can remove the muffler and look at the piston and cylinder wall through the exhaust port.If you see deep scratches,it is not cost effective to repair it.Grab the spark plug and try pushing it back and forth to see if the cylinder mounting bolts are loose.If loose,tighten.Next try moving the carb back and forth to see if it's screws are loose.
The fuel filter is attached to the end of the smaller fuel line entering the tank.There should be about 4 inches of line inside the tank with the filter on the end.It may have fallen off from the broken line.The larger line is the return line and only has about 1 inch of line in the tank.
There is a small screen inside the carb that may be partially blocked because of the missing fuel filter.The carb should be removed,disassembled,and cleaned with carb cleaner and low pressure air through all the small holes.If the diaphragms are stiff,they should be replaced with a Walbro K20-WAT repair kit (around $8).Here is a link to the Walbro WT carb manual.Hope this helps.
http://wem.walbro.com/distributors/s...s/WTseries.pdf
usmcgrunt is offline
post #3 of 19 (permalink) Old 10-27-2012, 04:20 PM Thread Starter
Member
Wow, I am starting to think I may need to toss this thing. I just took the carburator completely apart, cleaned the ports with a tiny wire and blew all the holes out. I rearranged the fuel line in the tank, which does not have a filter and did not have one when I got the machine. I got it started and it ran for about 20 seconds this time but stopped again. Then it would start then quickly stop again and again. I have rechecked the screws and bolts, which appear tight. Well, I think the next step is bye bye. Thanks for your reply and information.
post #4 of 19 (permalink) Old 10-27-2012, 06:37 PM
Elder Statesman
Quote:
Don't give up quite yet, when you pump the primer do you see air bubbles in the fuel line, if so the fuel line in the tank is out of the fuel, the filter is the weight that keeps the fuel line where the fuel is, tie something on the end of the fuel line to see if it will stay running, if it does, get a filter, if it doesn't you have other problems. If part of the fuel lines was bad they are all bad. Have a good one. Geo
geogrubb is offline
post #5 of 19 (permalink) Old 10-27-2012, 07:27 PM Thread Starter
Member
Good idea. I will try it. Thanks!
post #6 of 19 (permalink) Old 10-27-2012, 10:02 PM
Elder Statesman
Pretty sure you will need replace the gaskets/diaphragms and the screen in the carb. Cleaning will not always do the trick. If it has not been run for awhile, the diaphragm is probably dried out and will not function properly. I have overlooked the screen before as it "looked" clean. Does it feel like it has descent compression when you pull the starter rope?
Rentahusband is offline
post #7 of 19 (permalink) Old 10-28-2012, 09:25 AM Thread Starter
Member
How do I get to the screen. The diaphram and gasket look to be in good condition. The screen could be the problem. The compression seems good. Thanks for the help.
post #8 of 19 (permalink) Old 10-28-2012, 10:15 AM
Member
I have found that sometimes the compression may read ok and still have loose cylinder head bolts as usmcgrunt has suggested - especially on Craftsman and Poulan models. The problem is on the downstroke of the piston not having enough pull to draw fuel properly. I suggedt you check the head bolts and use red loctite if they are loose.
John Lolli is offline
post #9 of 19 (permalink) Old 10-28-2012, 12:27 PM
Elder Statesman
Under the primer bulb side held on by two screws,is the fuel pump diaphragm and gasket.The carb manual (link posted earlier) shows the screen as item #55 in the main body of the carb.Below is a link that should help with cleaning and reassembly.As Rentahusband suggested,you should probably get a carb kit to do it right.
Have you dumped the fuel out of the tank and checked if the filter is laying in the bottom of the gas tank? I have the same blower which is 5 years old.After one carb rebuild and two cleanings,it still runs pretty good.I didn't mean to sound negative and scare you away from trying to repair it.I was just trying to make you aware of the possible trouble areas with most all two cycle engines.Please come back with further questions and let us know what you find or what you need to know to continue.
http://www.ereplacementparts.com/art...arburetor.html
post #10 of 19 (permalink) Old 10-28-2012, 01:33 PM Thread Starter
Member
Thanks, you weren't scaring me into dumping the blower. I did take the fuel tank out of the machine and clean the inside. I blew out the larger tube and replaced the smaller tube. There was no filter to be found. Only pieces of the original small tube. I noted that the diaphragm and the gasket appear to be in good condition. I will dig into the screen in the carb to see how it looks. I may go for a card rebuild kit when all is said and done. Many thanks for the helpful information. I will continue to deal with the fuel problem until I just can't deal with it any longer.
post #11 of 19 (permalink) Old 10-28-2012, 03:34 PM Thread Starter
Member
Quote:
Thanks!
post #12 of 19 (permalink) Old 10-29-2012, 03:09 PM Thread Starter
Member
To all the kind men who addressed my problem with the leaf blower. Today I took the carb apart and cleaned the screen. Put it back on the motor and away we went. Started right up and ran perfectly. I just ordered a new fuel filter to help protect the carb from fuel tank debris. I really appreciate all the guidance and advise. Best wishes to all.
post #13 of 19 (permalink) Old 10-29-2012, 04:22 PM
Elder Statesman
Great job on the repairI hope you get many years of service from it.
post #14 of 19 (permalink) Old 10-29-2012, 05:27 PM
Elder Statesman
Success is a wonderful sound. Since these blowers have a tendency/reputation for scoring the cylinder I suggest mixing the fuel a little rich for more lubrication, I think a little smoke is better than a trashed blower. Have a good one. Geo
geogrubb is offline
post #15 of 19 (permalink) Old 10-29-2012, 06:28 PM Thread Starter
Member
Quote:
Rich mix is already in the game plan. Thanks for your help.
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
