Replacement Carb for old Stihl FS 80 (TK carb) - HobbyTalk
Reply
post #1 of 23 (permalink) Old 08-16-2010, 09:16 AM Thread Starter
Member
Hi all!
Got an old Stihl FS80 with a TK carb (slide barrel) that will start but not run for more than 5-10 sec - it constantly floods out. I found a rebuild carb kit and installed - no difference. Compression is good (~150psi), great spark - I just hate to trash this thing.
I followed several strings about these TK carbs being known to wear and leak air into the carb. I have not "eliminated" the primer bulb or plugged up the overflow port -do you think this will help?
Lastly - I've searched the net for a replacement carb, but can't find one.
How would one go about matching a different (newer) carb to this - what things do I need to consider? Has anyone doe something like this?
Thanks for any help.
Best
quid_non
quid_non is offline
Sponsored Links
Advertisement
post #2 of 23 (permalink) Old 08-16-2010, 11:40 AM
Elder Statesman
Quote:
Originally Posted by quid_non View Post
Hi all!
Best
quid_non
Manual shows for FS80,85 the following, Zama C1Q-S63A, C1Q-S78 BR, C1Q-S56, C1Q-S60 BR, C1Q-28D, C1Q-S41A and Walbro WT-447
Have a good one. Geo
geogrubb is offline
post #3 of 23 (permalink) Old 08-16-2010, 03:50 PM Thread Starter
Member
Thanks - but this has the slide barrel carb (TK style) - will the ones you mention interchange with this? It is the OLD FS80.
Thanks
quid_non is offline
post #4 of 23 (permalink) Old 08-16-2010, 06:21 PM
Elder Statesman
Thanks
I do not know, maybe one of the other guys has the answer and will post after they get off work. Have a good one. Geo
geogrubb is offline
post #5 of 23 (permalink) Old 08-16-2010, 06:23 PM
Elder Statesman
Thanks
I do not know, the manual I used didn't show a TK carb so maybe it doesn't go back far enough, maybe one of the other guys has the answer and will post after they get off work. Have a good one. Geo
geogrubb is offline
post #6 of 23 (permalink) Old 08-16-2010, 11:53 PM
Member
A possible source for a replacement carb might be www.chainsawr.com
pioneer 1074 is offline
post #7 of 23 (permalink) Old 08-17-2010, 09:57 AM Thread Starter
Member
Thanks for the link Pioneer - an interesting site. Did not find any carbs here for trimmers.
Thanks!
quid_non is offline
post #8 of 23 (permalink) Old 08-17-2010, 12:39 PM
Member
Thanks!
You can try my site but i am sure if that is a stihl unit stihl and the carb manufactures made it impossible for non stihl dealers to get carbs for the stihl units so it may have to be special ordered from your stihl dealer
Lawnmowertech is offline
post #9 of 23 (permalink) Old 08-19-2010, 12:59 PM Thread Starter
Member
Thanks Lawnmower tech!
Still can't seem to find any info. Wondering if scouting local repair shops for discarded carbs is an option.
What does it take to put a different carb on an engine? What should I consider - Why can't I just put a walbro on instead of "TK" (I need to fabricate an adapter) but why not?
Thanks for any insight
quid_non is offline
post #10 of 23 (permalink) Old 08-25-2010, 08:45 AM
Member
I'm a Stihl dealer, & i'll check for you tomorrow. Stihl has a propriatary parts look up called Media Cat. FS80 isn't very old, so carbs should still be available. normaly for any product there will be several carbs listed in the look-up, the newest 'version' will be listed at the top. any chance you can post the serial number of the unit? Thanks, --Lucky
luckyvision is offline
post #11 of 23 (permalink) Old 08-25-2010, 08:50 AM
Member
as a start:
4112's:
(1) FS 80 E,(2) FS 80 AVE,(3) FS 80 RE,(4) FS 80 AVRE
carb is Stihl part # 4112 120 0611
there are 8 different carbs for units #4137
post #12 of 23 (permalink) Old 08-29-2010, 10:23 AM Thread Starter
Member
Thanks for the follow up Luckyvision - soorry it took so long to get back with yuo.
Serial #
Stihl FS80AVR 13654169
btw...
Tried the "modification" suggested by others (i.e. drilling out the "tickler valve" and plugging the overfolw port). (see: http://www.arboristsite.com/showthread.php?p=977903) This had no effect - the carb still floods out. Replaced /rechecked the float pin, spring and lever - - still floods the cylinder.
At a loss on what to try next - can't seem to locate a replacement carb...
quid_non is offline
post #13 of 23 (permalink) Old 08-29-2010, 01:15 PM
Elder Statesman
Serial #
btw...
Here is a Zama. Have a good one. Geo
http://cgi.ebay.com/Zama-Stihl-FS-80...item3a5e1ad9b4
Here is a TK carb kit.
http://cgi.ebay.com/TK-Carb-Kit-Full...item2c56e5aad3
geogrubb is offline
post #14 of 23 (permalink) Old 09-20-2010, 10:11 AM Thread Starter
Member
Thanks - still looking are a replacement carb or substitute. I installed a kit and it makes no difference. The zama is not a slide barrel type. Wondering if it will match up with the hole pattern on the case?
Any other suggestions??
Thanks
quid_non is offline
post #15 of 23 (permalink) Old 09-20-2010, 11:59 AM
Elder Statesman
Thanks
Refer to my first post, all of those carbs listed are for an FS80 the info came from the Stihl manual. Have a good one. Geo
geogrubb is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
