Poulan Pro only runs at full choke - HobbyTalk
post #1 of 6 (permalink) Old 08-09-2010, 08:55 PM Thread Starter
Member
Hello everyone. I have a Poulan Pro PPB335 trimmer which has been giving me trouble the past few weeks.
It started off bogging down somewhat under throttle, so I decided to take it to a shop to have it looked at. Well, a couple weeks later, after finding out no one locally will work on it, I decided to do it myself. I mean, I work on cars and stuff, how hard could it be?
Apparently a lot harder than it looks! I tried different gas, no luck. Then I rebuilt the carb, no luck there either! When I changed the gas, it started doing something different. It only runs at full choke! It runs at a midrange rpm, not idle but not wide open either. It will run at full choke for a least 3-4 minutes before dying. If I move it to half choke or open, it dies almost immediately.
It has a Walbro WTA31 carb, cyl compression is 115.
Any ideas?
ihate2cycles is offline
Sponsored Links
Advertisement
post #2 of 6 (permalink) Old 08-09-2010, 09:24 PM
Top Dog
30yearTech's Avatar
A dirty fuel filter in the tank.
Bad fuel hose.
Air leak into the crankcase.
Faulty high speed check valve in the carburetor.
Just to name a few. check all around the crankcase and make sure all attaching hardware is tight. A small air leak can cause these issues and is somewhat common on these engines.
30yearTech is offline
post #3 of 6 (permalink) Old 08-09-2010, 09:37 PM Thread Starter
Member
Whoops, left out a few things. Thanks for reminding me, lol!
Fuel filter is good, as are hoses. I'm leaning towards air leak, since I rebuilt the carb. This thing isn't even a year old yet, still under warranty (well it was until I opened it up!) but I didn't even think to send in the warranty card. Usually everything I buy breaks right after the warranty, bad decision on my part.
post #4 of 6 (permalink) Old 08-10-2010, 07:07 PM
Elder Statesman
Try spraying/dribble some carb/brakeparts cleaner, using the straw, behind the carb along the mating surfaces, if the engine tempo changes you have a leak. Have a good one. Geo
geogrubb is offline
post #5 of 6 (permalink) Old 08-11-2010, 07:43 PM Thread Starter
Member
Sure enough, the gasket between the carb and motor is leaking. Now I need to try to find a place around here that has it. If not, I'll just get it online.
Thanks for the help!
post #6 of 6 (permalink) Old 08-11-2010, 09:00 PM
Elder Statesman
You probably should order 2, I have found some of the aftermarket gasket material to be very thin, just don't block the pulse port if you pair them up. Have a good one. Geo
geogrubb is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
