Homelite Chainsaw wont start/run - HobbyTalk
post #1 of 5 (permalink) Old 07-18-2010, 09:26 PM Thread Starter
Member
I have a 33cc 16 in. Homelite chainsaw, model UT10947D.
I let my brother-in-law borrow it last year and he gave it back to me dead. He offered to pay for repairs but that's a different story.
I tinkered with it late last year for a while before setting it aside but now I've taken up the problem again and I'm still not having any luck.
When I first try to start it, it acts like it's going to run and it sputters for about 3 seconds and then stalls. After that, I get nothing. It did the same thing last year as well. I took the carburetor out last year and cleaned all the intake areas pretty well with some carb cleaner. Fuel runs out of the hoses fine. I tried a new spark plug and verified that it was sparking when I pull the cord with the plug unscrewed from the cylinder mach. I pulled the muffler off and cleaned the screen but it wasn't fouled much anyway. Tried some fresh gas/oil mix as well of course.
Anyone have an idea what the problem might be? Thanks.
plowe70 is offline
Sponsored Links
Advertisement
post #2 of 5 (permalink) Old 07-18-2010, 09:45 PM
Member
You don't think he might have put straight gas in it, do you?
glenjudy is offline
post #3 of 5 (permalink) Old 07-19-2010, 08:26 AM Thread Starter
Member
Quote:
Not likely. I gave him a jug of 50:1 that I mixed when I let him borrow it.
plowe70 is offline
post #4 of 5 (permalink) Old 07-19-2010, 12:12 PM
Member
Smile
How much compression does it have,needs to be 90# or better.Also check for loose screws at the insulator behind the carb.also see if the insulator is crack,that will cause a air leak and keep it from starting.Hope this helps.
Jerry
jsouth is offline
post #5 of 5 (permalink) Old 07-19-2010, 09:19 PM Thread Starter
Member
Well I think I found the problem. The fuel line is damaged. Looks like it might have been twisted and pinched off just above the tank. Not sure how it could have gotten into that condition. Must be the gas that I thought was feeding up through the fuel line was actually excess gas from the primer bulb hose. Thanks for the suggestion.
plowe70 is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
