Craftman Weedwacker Carb Adjustment - HobbyTalk
post #1 of 4 (permalink) Old 06-23-2010, 08:26 PM Thread Starter
New Member
I have a 24cc Craftsman Weedwacker. I rebuilt the carb but need to find the settings for the high speed needle. Anybody know how many turns to start with? The plastic limiter cap is damaged and so I am starting from scratch. Thanks.
bensonfamily1 is offline
Sponsored Links
Advertisement
post #2 of 4 (permalink) Old 06-24-2010, 10:20 PM
Member
Tamfan's Avatar
Quote:
You can pull the limiter cap off with a pair of pliers (straight out and use care). Your call if you want to do this, especially if it's already damaged.
Carefully turn needle CW until it feels like it just begins to seat. When it feels like it is getting close, stop. Then back out CCW 1 1/4 turns. Some may require starting at 1 1/2 turns. Either way this will get you your starting adjustment. Works for both L & H adjustments.
Afterwards, make adjustments in 1/8 increments until you find the setting you want. I'm no expert but this is what I have learned.
Good Luck.
Tamfan is offline
post #3 of 4 (permalink) Old 06-25-2010, 09:20 AM
Member
junebug1701's Avatar
Assuming your engine has the Hi and Lo needles, the Hi one will be further from the engine, and the Lo will be closest to the engine. Most any Walbro carb'ed engine will start and run (very richly, though) with both screws between 1.5 and 2 turns out from gently closed. Once she fires, she should run with the choke open, but the engine will be down on power and smoke a lot. Time to start tuning.
First, hold the throttle wide open, and slowly close the Hi needle (further from the engine). The engine will smooth out and speed up. Note where the engine begins to sound smooth, and continue closing the needle (called leaning) until the engine begins to stumble and get rough again. Note this position, and then set the Hi needle to a little to the rich side of the middle of the 2 points you noted..... Hope that's clear...
Now, go to idle. Let the engine idle a little bit (30 seconds or so). Open the throttle and see how it performs. Probably it'll stumble, sputter, smoke and maybe quit. If so, lean the Lo needle a bit (closest to the engine) and try again. If it simply quits immediately, the idle is lean and you'd need to open the Lo needle slightly. Repeat this until the engine accelerates from an idle cleanly to full throttle.
Because the idle jet has some effect on the main jet, after you get the idle working right, just revisit the Hi needle as described above to fine tune it. You want it set a bit towards the rich side of the 2 stumble points for best performance and engine life.
A quick caution for you... When the engine is being tuned, don't tune it so it's always running completely flawlessly smooth. It's safer if you rich it just slightly, so once in a while it burbles slightly. That's a sign of a slightly rich mixture, and since our oil is in the gas, it helps ensure adequate oil. Just the slightest, most occasional burble when the engine's under low load (not cutting) is great. Once line meets grass, the load goes up and the engine will produce best power.
junebug1701 is offline
post #4 of 4 (permalink) Old 06-29-2010, 09:53 AM Thread Starter
New Member
Smile Thanks
Thanks for the responses. That's exactly what I was looking for.....
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
