Weed eater stalls when given throttle - HobbyTalk
post #1 of 6 (permalink) Old 05-18-2010, 01:26 PM Thread Starter
Member
I have a Sithl FS85 Weed wacker that starts up after a few pulls (sometimes it takes 10-15 pulls...but it eventually starts)....It will idle just fine, nice and smooth, but when you give it gas it dies out....you can play with the gas a little...example would be to give it slow gas and let it rev up slow, but it eventually dies out. That is my problem.
Here is what i have exactly:
Stihl FS85 trimmer that has a Zama C1Q Carb.
Here is what I have done so far to fix it (nothing for me has worked yet):
New fuel filter.
New air filter.
Cleaned spark arrestor screen.
Cleaned spark plug.
New fuel lines.
I pulled the carb apart and 'wiped' it down...it did not seem very dirty anyways.
New primer bulb.
nate81 is offline
Sponsored Links
Advertisement
post #2 of 6 (permalink) Old 05-18-2010, 05:38 PM
Member
Maybe you crossed your fuel lines when you hooked back up.
andybcumming112 is offline
post #3 of 6 (permalink) Old 05-18-2010, 05:49 PM Thread Starter
Member
Quote:
I have been having this problem for a few weeks now. After finding out how much the repair shop wanted, i decided to fix it myself but i need some advice and help.
If i had the lines crossed....would it even start? It idles like a dream, but when i give it a little gas...it stalls...
nate81 is offline
post #4 of 6 (permalink) Old 05-18-2010, 08:07 PM Thread Starter
Member
I solved the problem....while in the bathroom to be exact!!
nate81 is offline
post #5 of 6 (permalink) Old 05-19-2010, 09:49 AM Thread Starter
Member
it called for 89 or higher octane w/ the oil mix. I was putting 87 octane/oil mix ...i tried the 89 and it runs like a dream.
nate81 is offline
post #6 of 6 (permalink) Old 06-04-2010, 05:58 AM
Member
Quote:
That little difference in octane should not prevent running so you might have had bad gas.
Another thing that could cause such is insects or something building nest in exhaust. Could not get above a rough idle speed when mud daubers plugged mine.
E_Net_Rider is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
