Stihl BG85 - will only idle - HobbyTalk
post #1 of 10 (permalink) Old 05-16-2010, 10:01 PM Thread Starter
Member
This leaf blower starts and idles fine, but sputters out as soon as I try to rev it up. I can feather it to full speed, but then it will sputter and die.
I cleaned the air filter, changed the gas (use stihl oil/mix), shot in some carb cleaner, and tried leaving the cap partially open -- same result.
Any other ideas? I have 2 carb adjustment screws that I haven't touched.
walkman is offline
Sponsored Links
Advertisement
post #2 of 10 (permalink) Old 05-16-2010, 10:23 PM
Member
Check the exhaust screen and make sure its not clogged. If its not clogged then your issue is in the carburetor, it more then likely needs a good cleaning and maybe a rebuild.
rotti1968 is offline
post #3 of 10 (permalink) Old 05-17-2010, 12:44 AM Thread Starter
Member
I'll check the exhaust.
If the carb in the culprit, how hard it is to get parts and rebuild a Stihl carb? I replaced a diaphram on my lawnmower last summer which was cheap and easy.
walkman is offline
post #4 of 10 (permalink) Old 05-17-2010, 12:22 PM
Elder Statesman
Before you start taking it apart try opening the H adjustment screw about 1/4 turn. Have a good one. Geo
geogrubb is online now
post #5 of 10 (permalink) Old 05-17-2010, 01:59 PM Thread Starter
Member
exhaust - checked and it was in good and clean condition.
H adjustment - still sputters and dies at full throttle.
walkman is offline
post #6 of 10 (permalink) Old 05-17-2010, 04:04 PM
Elder Statesman
Here are the adjustment instructions, if they don't help then it will be necessary to remove, clean and install a carb kit. Have a good one. Geo
post #7 of 10 (permalink) Old 05-17-2010, 04:48 PM Thread Starter
Member
Carb adjustment doesn't accomplish anything.
Is is practical to rebuild the stihl carbs one self? I'm not finding much on-line to buy a kit -- which doesn't surprise me with Stihl.
walkman is offline
post #8 of 10 (permalink) Old 05-17-2010, 07:40 PM
Elder Statesman
Your blower will have a Zama C1Q carb, S50, S55, S64 or S68A.
Kits RB=Rebuild GND=Gasket and Diaphragm
S50 kit is RB-79 - GND-39
S55 kit is RB-89 - GND-50
S64 kit is RB-89 - GND-50
S68A kit is RB-99 - GND-56
I suggest you take the carb with you if you have a small engine shop locally and they can give you the proper parts. Have a good one. Geo
post #9 of 10 (permalink) Old 05-17-2010, 08:40 PM
Member
stihl part #'s 4229 007 1060 or 1129 007 1062 depending on your carburetor it will be either one of these kits.
post #10 of 10 (permalink) Old 07-24-2010, 01:49 PM
Member
Bg 85
The problem is in the carburetor. There is a glue around the welch plug that comes apart and loads up the leaf blower. You can buy one for about $30 at your local dealer.
StihlGuy is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
