poulan chainsaw - HobbyTalk
post #1 of 11 (permalink) Old 04-20-2010, 11:59 AM Thread Starter
Member
poulan chainsaw
Hi guys, I have a 5 year old poulan woodshark model 1950. It has run like a dream until this year, ran good all spring and then I decided to clean it up, changed the spark plug and cleaned the air filter. After the saw ran well for a couple hours and now:
starts with the choke engaged half way, but stalls the instant the throttle is not applied, and I mean the split second. Will not start with choke fully engaged and stalls the instant it is. The fuel is new, the fuel filter is clean, fuel lines are new. The carb is clean as new. To restart even if warm I must apply the choke half way and rev it up.
I'm sure this is something I buggered up while cleaning it up. Appreciate any help, Ryan
Campbery is offline
Sponsored Links
Advertisement
post #2 of 11 (permalink) Old 04-20-2010, 01:14 PM
Member
Quote:
I have one of these in my Poulan posse, has been a great little saw.
Can you clarify the 'is's' and 'is nots' ? I'm easily confused.
I've done total tear-downs and reconditions on 8 of these models this winter.
You might lightly seat both the L and H needles, turn H out 1 1/2 and L 1 3/4. see what happens,,,,,
thanks,
glenjudy is offline
post #3 of 11 (permalink) Old 04-20-2010, 01:52 PM Thread Starter
Member
thanks for the reply, stalls when the throttle is NOT engaged instantly, only starts when choke is at 1/2 and throttled up
Campbery is offline
post #4 of 11 (permalink) Old 04-21-2010, 09:23 AM Thread Starter
Member
Is there a special tool for adjusting the L and H needles??
thanks,
Campbery is offline
post #5 of 11 (permalink) Old 04-21-2010, 06:13 PM
Member
Mine just need a small flat blade screwdriver.
glenjudy is offline
post #6 of 11 (permalink) Old 04-21-2010, 10:15 PM
Member
depends on the model but it is very well possible. all you have to do is look at it. if its round like then yes, if it has groves in it for a screw driver well there you go. may need to clean the carb and or replace the fuel filter. but try adjusting first, if that fails then do the tear down
LowRider is offline
post #7 of 11 (permalink) Old 04-21-2010, 11:22 PM Thread Starter
Member
yah the needles have rounded ends, but have access holes from outside the saw so I guess either take it apart or get the tool, thanks again
Campbery is offline
post #8 of 11 (permalink) Old 04-22-2010, 11:29 AM Thread Starter
Member
carb tuning
OK I seated the needles and now the saw starts easy and runs well with choke again on 1/2 but smokes when throttle engaged, how should I adjust the carb from here? thanks
Campbery is offline
post #9 of 11 (permalink) Old 04-22-2010, 11:31 PM
Member
did you seat them to spec or did you just turn them till you got it running?
LowRider is offline
post #10 of 11 (permalink) Old 04-23-2010, 06:57 AM
Member
What fuel mixture are you running?
Are you saying it won't run unless it's 1/2 choked?
Does it accelerate quickly when you blip the throttle?
glenjudy is offline
post #11 of 11 (permalink) Old 04-23-2010, 04:04 PM Thread Starter
Member
Thanks for your help guys, watched a couple youtube videos on the subject and got the carb tuning figured out. One thing, when I inspect the airfilter after even a few minutes use there is fine particles that seem to be coming out of the carb? Looks like fine sawdust but is hard and smells like fuel. Would this be my fuel filter breaking down. Looks like new. Thanks again.
Campbery is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
