Stihl chainsaw won't fire - HobbyTalk
post #1 of 12 (permalink) Old 07-24-2008, 09:14 PM Thread Starter
Member
Question Stihl chainsaw won't fire
I have a Stihl chainsaw that has only about 10-15 hours of running time on it. It had been sitting in my garage for about a year and a half with old fuel. I should haven't keep the fuel in it but replaced it with a new mixture, checked the fuel filter and it was clean, and it refuses to fire. I replaced the plug in spite of the fact that the original looked ok and showed spark and it still won't start or even give an indication of firing. I then put about a tablespoon of gas in the cylinder without any hint of firing. There isn't any physical damage to it and it feels like it has good compression. The last time I did use it starting was effortless and now nothing. I'm not a small engine genius but two cycle engines aren't that complicated. Does anyone have a suggestion?
mjw2025 is offline
Sponsored Links
Advertisement
post #2 of 12 (permalink) Old 07-24-2008, 10:02 PM
Top Dog
30yearTech's Avatar
What model chainsaw do you have??
30yearTech is offline
post #3 of 12 (permalink) Old 07-24-2008, 10:18 PM Thread Starter
Member
It's a MS290 "Farm Boss".
mjw2025 is offline
post #4 of 12 (permalink) Old 07-26-2008, 11:17 AM
Member
check for loose case/cyl bolts or a sheered flywheel key.
is the plug wet?
if you bought it new, or transfered the warrenty, & it's under a year old (homeowner use) it is under warrenty, (gummed up carbs are not covered)
--Lucky
luckyvision is offline
post #5 of 12 (permalink) Old 07-26-2008, 01:31 PM
Elder Statesman
justin3's Avatar
Send a message via AIM to justin3
Its possible you flooded your engine with the tablespoon of gas u put in the cylinder. Let it sit for awhile with the plug removed to dry out the cylinder. Also a good idea to replace the spark plug while your at it.
justin3 is offline
post #6 of 12 (permalink) Old 07-26-2008, 08:58 PM
Member
yeah, a shot of carb cleaner in the carb or plug hole is usually sufficent to get it to kick...
post #7 of 12 (permalink) Old 07-27-2008, 11:24 AM Thread Starter
Member
Although it's about three years old, operationally it's almost new as I have relatively few hours of running time. The last time I used it starting was similar to when it was brand new so I don't think it's something such as the flywheel key. My thoughts, as suggested here, is that I'm flooding it so I'm going to give the techniques suggested her a try. One suggestion was shot of carb cleaner in the cylinder or carb and my question is if carb cleaner is similar to starting fluid? The reason I ask it that I've read that starting fluid can be pretty hard on the engine.
Thanks
mjw2025 is offline
post #8 of 12 (permalink) Old 07-30-2008, 10:23 AM
Member
starting fluid is straight either & will wash the oils off the cyl walls, carb cleaner contains oils & won't harm the cyl as long as you don't 'run' the machine off it.
post #9 of 12 (permalink) Old 08-11-2008, 03:08 PM Thread Starter
Member
I finally got around to trying your suggestion and it worked.
Thanks
mjw2025 is offline
post #10 of 12 (permalink) Old 08-11-2008, 03:16 PM
Member
Quote:
Thanks
so what was it ??
COMP is offline
post #11 of 12 (permalink) Old 08-11-2008, 04:14 PM Thread Starter
Member
It was squirting carb cleaner into the cylinder. My response was directed to Luckyvision, who suggested it, but I forgot to specify. I appreciated everyone else's help too.
mjw2025 is offline
post #12 of 12 (permalink) Old 08-11-2008, 04:15 PM
Member
COMP is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
