Bolens BL100 weed eater wont start - HobbyTalk
post #1 of 6 (permalink) Old 06-19-2006, 11:02 AM Thread Starter
New Member
Unhappy Bolens BL100 weed eater wont start
I have a Bolens BL100 gas trimmer and it wont start. I've tried new fuel and spark plug still wont start. Is there anything else I can do before I have to break down and take it to a repair shop.
atipikal is offline
Sponsored Links
Advertisement
post #2 of 6 (permalink) Old 06-19-2006, 01:08 PM
Member
Check for a spark and it fuel's getting through the line to the carb ok. If there's a spark and fuel in the line, then you've probably got a gummed up carb if the trimmer's sat there for some time. If you aren't sure what to do with the carb, its best to take it to a shop.
Munkey is offline
post #3 of 6 (permalink) Old 11-11-2008, 04:28 PM
New Member
Quote:
Ihave the same weedeater with spark,do i need a new coil
james ellison is offline
post #4 of 6 (permalink) Old 11-11-2008, 06:06 PM
Elder Statesman
justin3's Avatar
Send a message via AIM to justin3
Quote:
Dissconnect the kill wire from the coil, check the air gap in between the flywheel and coil,it should be .010"-.014" and make sure the flywheel magnet has enough magnetism to hold a good size screwdriver to it. If you still do not get spark then your coil is probably dead.
justin3 is offline
post #5 of 6 (permalink) Old 11-11-2008, 06:36 PM
Member
Is your plug fouling. If your plug is bone dry when you check it then you have a gummed carburator and no gas is getting to the cylinder. If you have a wet plug when you check it then I would look at buying a new coil. Also is your plug gapped properly? That can make a pretty big difference.
dj722000 is offline
post #6 of 6 (permalink) Old 11-11-2008, 06:55 PM
The Shadow
hankster's Avatar
How is the compression? Pull off the muffler and look for scoring. This is a MTD/Ryobi design unit.
Hank
hankster is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
