Carb adjustment tool for Poulan/Crapsman? - HobbyTalk
post #1 of 15 (permalink) Old 09-20-2005, 09:14 AM Thread Starter
Member
2strokin's Avatar
Question Carb adjustment tool for Poulan/Crapsman?
Have a new "Crapsman"32cc Brush trimmer that has carb adj screws with an external spline instead of a slot for screwdriver. Sears is no help/Local mower shop says they can get one and never saw one(!!??) Any source you might suggest? The screw looks like the shaft of an older car radio-round head with external splines.If I could just get it out I can cut a groove to make a flat screwdriver work, but....
2strokin is offline
Sponsored Links
Advertisement
post #2 of 15 (permalink) Old 10-02-2005, 09:57 PM
dji
Member
I was looking for the same tool about a month ago. Went to my local shop and 1 of the the guys sold me his out of his tool box for $5..what a deal. So they do make them...
dji is offline
post #3 of 15 (permalink) Old 10-02-2005, 10:32 PM
The Shadow
hankster's Avatar
For the most part they are only suppose to be sold to techs. I should have some for sale next week.
Hank
hankster is offline
post #4 of 15 (permalink) Old 10-03-2005, 09:13 AM Thread Starter
Member
2strokin's Avatar
Talking Poulan/Crapsman carb tool
well, I got tired of not being able to use my Brushtrimmer and took the bul by the horns. I removed carb & hacksawed a slot into both adjustment screws so I can now use a flat screwdriver. Brutal but effective...
2strokin is offline
post #5 of 15 (permalink) Old 03-03-2006, 11:27 PM
Member
greyheadedguy's Avatar
Seems like I could get the same effects on those screws with my Dremel and a cutting wheel? If the wheel was slightly worn it could fit into a tight space. I've got one (a Poulan Blower) I need to fix tomorrow if the owner will let me.
greyheadedguy is offline
post #6 of 15 (permalink) Old 03-04-2006, 12:15 AM
HobbyTalk Pro
bugman's Avatar
Yeah, it would work great.
bugman is offline
post #7 of 15 (permalink) Old 06-07-2007, 10:24 PM
New Member
a tool to adjust the carb on a Weedeater and Many other carbs can be easily
fabricate from a straight screw driver and a female electrical wiring connector
commonly used for auto wiring. Use a blue colored connector. Push a suitable
size screwdriver into the female spade and glue it with epoxy cement.
The plastic part where the wire is normally crimped can be gently tapped on to the adjustment screw head with a couple of light taps. Your new tool is
finished. The outer screw is the high speed adj & the inner screw is the idle
adj. If the engine won't start screw the high speed screw 1/4 turn counter-clock wise and try to start again. Repeat adjusting screw 1/4 turn at a time
OkieDave is offline
post #8 of 15 (permalink) Old 06-08-2007, 07:40 AM
Elder Statesman
I found these tools on E-Bay. Look under Poulan Craftsman Walbro carb adjusting tool. They were about $10.00.
RKDOC is offline
post #9 of 15 (permalink) Old 06-08-2007, 10:13 AM
Member
I make my own tool, using a piece of 1/4" dowel rod, center drill it with a 9/64" drill bit and then gently tap it on the screws, this works for both kinds of tamper proof adjusters.
parttime is offline
post #10 of 15 (permalink) Old 07-01-2007, 01:24 AM
Member
craftsman 25cc bushwacker hedge trimmer carb
I recently removed the carb adjuster pins and dremeled a slot on each one to be able to adjust with a flat head screwdriver. But now I am not sure which pin goes back in which hole. one is longer than the other. Next their are 2 gaslines, a larger one and a smaller one, which goes on top carb input and which goes on bottom ? Once I figure this out then how do I start adjusting the pins to get it to run again. It keeps flooding and won't run. I tried choke on ,off etc. adjusting the pins 1/4 turn at a time.... HELP !!!
RMTK is offline
post #11 of 15 (permalink) Old 11-17-2012, 12:13 PM
New Member
Bic pen to the rescue
Reading the dowel tip, I had none so I took a bic ben, removed the pen and tapped the pen over the screw, being plastic no damage to screws. worked well but started to spin on the main part of the pen so I took that off and slotted the tip of the pen and turned with screwdriver.
Kjanvier is offline
post #12 of 15 (permalink) Old 11-17-2012, 12:56 PM
Elder Statesman
Quote:
Welcome to Hobby Talk.That's a great tip for those who don't have the correct tool.Thank you for sharing with all of us.
usmcgrunt is offline
post #13 of 15 (permalink) Old 06-25-2013, 08:16 PM
Member
carb adjusting tool
hey guys the simplest way to fix this problem is to just take off the carb and put it in a soft jaw vice and use a hacksaw cutting through the casting and screws at the same time. try to get it as centered as possible. any machine i work on which has this type adjusting screws i slot them. I have used every trick I have ever seen but this is by far the simplest.
ollie is offline
post #14 of 15 (permalink) Old 06-25-2013, 10:49 PM
Elder Statesman
Quote:
No need to remove the carb, check the pic below. Have a good one. Geo
geogrubb is offline
post #15 of 15 (permalink) Old 06-25-2013, 10:51 PM
Elder Statesman
A Dremel tool with a metal cutting disc is faster and easier.
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
