Northern tool - HobbyTalk
post #1 of 7 (permalink) Old 11-10-2012, 05:41 PM Thread Starter
Member
G.MAN's Avatar
Northern tool
[B]ANYONE HAVE EXPERIENCE WITH THEIR PRODUCTS SUCH AS GENERATORS.I LOOKING TO PURCHASE A 10,000 SURGE 8,500 WORKING WATT GENERATOR FROM THEM.IT HAS THE HONDA GX390 11HP. DOES ANYONE KNOW ABOUT THE THE QUALITY OF THE GENERATOR END, IT IS CALLED NORTHSTAR
G.MAN is offline
Sponsored Links
Advertisement
post #2 of 7 (permalink) Old 11-12-2012, 07:02 AM
Elder Statesman
I think it would be fine. It kind of depends on how much and how hard you use it, along with maintenance.
Rentahusband is offline
post #3 of 7 (permalink) Old 12-01-2012, 11:35 PM
Member
Northern Tool
If nothing else keep us posted. Northern Tool seems to hold its own and a Honda engine speaks for itself.
Wish they had a propane unit with good reviews.
By the way hello from Yorktown Heights.
walther is offline
post #4 of 7 (permalink) Old 12-02-2012, 11:44 PM
Member
walther,
Thanks again for reporting negative feedback on the propane generators,I should have done more research before refering you to them.
Don
Don L is offline
post #5 of 7 (permalink) Old 12-12-2012, 04:23 PM
Member
My experience comes from working maintenance at a wastewater treatment plant. A WW plant and collection system uses all sizes of generators to power mainly power pumps. This is what I learned from working with engineers : an alternating electric motor draws up to 8 times its full load amps (fla) on start up. A resistive load such as an electric heater will pull the same amps whether its on start up or not. So when buying a generator first determine how much load will be used to power motors ( find a motor face plate for this data, call someone in hvac sales, whatever) and how much will be resistive(lights,stove,whatever). Convert all amps to watts (multiply amps by the voltage used(120v,22ov). Next to to keep from overloading the system add 15% of load watts to the load figure.You've just sized your generator.
Two things about air conditioners :
1. for example a 3 ton unit may normally run on 15 to 25 amps(it all
depends on its efficiency and the amount of load its facing. Again
for example if it ran on 15 amps then 15 amps x 220 volts x 8 =
26400 watts. Actually I have heard on ac's being run on a lot less,
but what Ive told you is what engineers use.
2. Bear in mind that I'm not good at describing this but I'm trying to
give you enough background to ask questions. Here goes.
Generators made for home use may or may not be center tapped.
dirksenshoe is offline
post #6 of 7 (permalink) Old 12-12-2012, 10:37 PM
Member
I do'nt know how accurate this is but I found this guide at http://www.harborfreight.com/generat...ing-guide.html.
Don L is offline
post #7 of 7 (permalink) Old 12-12-2012, 10:45 PM
Member
Oops,for some reason I can't get that link to work but you can go to Harbor Freight's website and go to generators if you can't get the link to work.They have a guide that lists the estimated wattage of common appliances and tools.
I think I fixed the link in the last post.
Don L is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
