Help with an Atlas 520 snowblower - HobbyTalk
Reply
post #1 of 16 (permalink) Old 11-27-2008, 12:19 PM Thread Starter
Member
I just bought a used Atlas 520 snowblower,but the guy didn't have the manual for it.Would anyone know where I could find one,or at the very least would someone know what the proper fuel oil mixture would be for it.If it matters it is a 5 HP Briggs and Stratton.
Thanks in advance for any help anyone can offer me.
Duane3 is offline
Sponsored Links
Advertisement
post #2 of 16 (permalink) Old 11-27-2008, 11:20 PM
Elder Statesman
paulr44's Avatar
As far as I know, Atlas went out of business years ago. My Dad had one in the '60's. Don't think you'll be able to find a manual, much less any parts.
You ask about the fuel oil mixture - is this a 2-stroke? Wasn't aware they made one, for that matter didn't think Briggs made a 2-stroke snow engine until the '80's. If it is, there's a cut-off for running 2-strokes on today's 50:1 mix, and given the age of yours, I'd run 32:1 or even 16:1.
If the engine is exposed, and has an oil fill plug near the bottom of the block, it's a 4-stroke. 4-strokes don't use mix, they use straight gas in the tank, and 5W30 in the crankcase (for winter use).
paulr44 is offline
post #3 of 16 (permalink) Old 11-28-2008, 11:48 AM Thread Starter
Member
The guy that sold it to me said it was a 2 stroke,but I'll look for the drain plug just to verify that.Thanks for the info.
Duane3 is offline
post #4 of 16 (permalink) Old 11-29-2008, 05:19 AM
Member
Call MTD tech. line at 800-228-9683 they can look up parts for atlas
bgbass is offline
post #5 of 16 (permalink) Old 11-30-2008, 06:52 PM
Elder Statesman
paulr44's Avatar
Amazing. Haven't even seen one in decades. Nice to hear you got support.
Paul
paulr44 is offline
post #6 of 16 (permalink) Old 11-30-2008, 10:35 PM
Member
hdman97's Avatar
Are you sure he didn't say 2 stage? refering to the snowblower.
hdman97 is offline
post #7 of 16 (permalink) Old 12-01-2008, 05:03 PM Thread Starter
Member
Quote:
No,he said 2 stroke.Maybe he meant to say 2 stage.
Duane3 is offline
post #8 of 16 (permalink) Old 12-03-2008, 11:43 AM Thread Starter
Member
Yep,it has a fill plug near the bottom of the block so that takes care of that.
Thanks for the info guys,I appreciate the help.
Duane3 is offline
post #9 of 16 (permalink) Old 12-04-2008, 12:57 PM
Member
hdman97's Avatar
Most 2 stage blowers I've seen are 4 cycle,and 2 cycle are single stage.
hdman97 is offline
post #10 of 16 (permalink) Old 12-04-2008, 09:08 PM
Elder Statesman
paulr44's Avatar
This is true for the most part for the last say, 40 years. But, previous to that, numerous units were made with a four-stroke engine, and a single-stage, high-speed auger/impellor. Kind of a predecessor to the Toro S-200 series, but all metal, and very dangerous. Atlas, Reo (Reo was bought by Wheel-Horse), and Toro much such models. I think Lambert made one too. Remember the Toro Power-Handle, or Snow-Hound? I worked on a lot of Reo's, even into the 1980's. Also, Sears/Crafts. had an unusual one - a single stage, but the auger-impellor sat sideways like a 2nd stage impellor, so the intake was controlled and managed by forward motion alone. Had funky rods, like studs welded onto the impellor blades to chop up chunks.
Paul
paulr44 is offline
post #11 of 16 (permalink) Old 12-08-2008, 08:04 PM
Elder Statesman
power handle? do you mean powershovel by chance?
and I have never seen a 2 stroke 2 stage, I don't even think a 2-stroke would have enough torque to do something like that
pyro_maniac69 is offline
post #12 of 16 (permalink) Old 12-09-2008, 07:58 PM
Elder Statesman
paulr44's Avatar
Toro Power Handle was just that - an engine on a plate, with a handle, a clutching and a throttle control. You could put it on an lawnmower, edger, snowblower or tiller, possibly more but those ones I've seen.
See 1956 in link:
http://www.thetorocompany.com/compan...ory_1950s.html
paulr44 is offline
post #13 of 16 (permalink) Old 12-08-2011, 05:14 PM
New Member
According to an Atlas owner's manual for the 2-cycle A3222J & A3222ESJ models the proper oil is TC-W 2-cycle oil and the mixture should be 1:32 (4oz. oil per gallon of gas). I just bought a used Atlas (also without a manual) and found this website for downloading manuals: http://www.hammerwall.com/Manuals/Atlas/593/ . Now all I need to do is find out which model I own (haven't found any ID labels on it yet), I'm guessing it's the single-stage. Odd that all the single-stage manuals on that site are all for the same model (even though the site specifies otherwise). It probably doesn't matter, though. Checking the other manuals it seems that only the single-stage units need to have oil added to the gas, not the dual-stage units.
Moodie-1 is offline
post #14 of 16 (permalink) Old 12-08-2011, 05:59 PM
Member
No need to worry about ratio, just buy a good name brand 2 cycle oil, mix a small bottle to a gallon of gas and it will work fine, that is all we used in the shop for over 25 yrs and never had any problem, we used stihl or tanaka oil when we could get it, you can also use echo, stay away from store brands and ones such as homelite, etc. My CCR2000 toro is now about 30 yrs old and still going strong on this mix.
duffer72 is offline
post #15 of 16 (permalink) Old 12-08-2011, 06:28 PM
Top Dog
30yearTech's Avatar
Quote:
Originally Posted by duffer72 View Post
name brand 3 cycle oil,
Hmmmmm, I don't believe I have ever run across any of that type of oil before. Where can you buy it, and what's the engine that uses it look like?
Got any pictures?
30yearTech is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
