3.5 briggs and stratton rough idle - HobbyTalk
Reply
post #1 of 34 (permalink) Old 04-28-2008, 02:50 PM Thread Starter
Member
Unhappy 3.5 briggs and stratton rough idle
i have a briggs and stratton engine mounted on a lawnmower.
model 10D902
type 0129 B1
code 03021754
starts ok but runs very roughly surging and dropping, can see the governor moving back and forward with surges.
fuel,oil and spark plug ok.hope someone can help
skytronic is offline
Sponsored Links
Advertisement
post #2 of 34 (permalink) Old 04-28-2008, 04:07 PM
Member
Remove and clean carb, then install new carb diaphragm B&S P/N 795083.
tommyj3 is offline
post #3 of 34 (permalink) Old 05-01-2008, 12:33 PM Thread Starter
Member
hi tommyj3 removed and cleaned carb fitted new diaphragm but its still idling roughly any ather sugestions. thanks
post #4 of 34 (permalink) Old 05-01-2008, 01:05 PM
Member
What I would do is put about 2 ozs of fuel additive in a full tank of gas. Start engine let it run, and see if the additive cleans any crud that may still be in the carb. I personally use Sea Foam Fuel Additive for this.
tommyj3 is offline
post #5 of 34 (permalink) Old 05-01-2008, 03:09 PM
Member
When you removed carb and cleaned it, did you check the fuel inlet pipe and clean it as well? I'm not sure if this has the screen on the bottom of the pipe or on the side, but in either case, a dirty inlet can starve the engine and cause it to 'hunt'.
dawgpile is offline
post #6 of 34 (permalink) Old 05-02-2008, 07:36 AM Thread Starter
Member
hi,yes cleaned the gauze at the bottom of inlet pipe.took it apart again and cleaned blew air through jet and body ,still idling roughly ,racing and slowing down.
post #7 of 34 (permalink) Old 05-02-2008, 10:59 AM
Elder Statesman
did you put the gasket and diaphram on the correct way? if you didn't put those on than it will not run coreectly
pyro_maniac69 is offline
post #8 of 34 (permalink) Old 05-02-2008, 11:11 AM
ajp
Member
rough running
Quote:
remove and check spark plug. It could be fouled partially. After cleaning check gap. REinstall. if still rough then the mixture screw may be at fault. Use a screwdriver to first adjust lower screw 1/2 turn either in or out. If problem still exist go to top screw and turn 1/2 turn inand out. Your problem can be old gas also. If all these dont correct the problem them it could be the points. check back later...
ajp is offline
post #9 of 34 (permalink) Old 05-02-2008, 09:45 PM
Elder Statesman
oh, I'm sorry, I didnt look at the model number, I was unaware it was an older style diaphram carb
post #10 of 34 (permalink) Old 05-02-2008, 10:08 PM
Top Dog
30yearTech's Avatar
It's not that old, and there are no adjustments on this carburetor skytronic, so don't look for any. It is possible that old gas can cause a problem, your engine has no points either solid state ignition, a partially sheared flywheel key can cause a rough running engine too.
Pyro, this is a pulsa prime carburetor, your inquiry about gasket and diaphragm orientation is a valid question.
30yearTech is offline
post #11 of 34 (permalink) Old 05-03-2008, 12:21 AM
Elder Statesman
ah ok, I saw the 10D model number and thought that it might have been an older model series
thanks 30year
post #12 of 34 (permalink) Old 05-03-2008, 12:22 AM
Elder Statesman
I REALLY need partsmart on my computer or something
post #13 of 34 (permalink) Old 05-03-2008, 12:39 AM
Top Dog
30yearTech's Avatar
You can find parts look up and various sites on line, like partstree.com, jackssmallengine.com and of course briggsandstratton.com, may be a little slow if you have dial-up but otherwise pretty useful for looking up or at IPL's
post #14 of 34 (permalink) Old 05-19-2008, 08:01 PM
New Member
Very similar question
I think I have the same basic motor and carb. Mine is Model 9D902. This is a small Murray mower with the "throttle free" carb. Someone left behind when I moved in and looks to be used very little.
Prime it and it cranks first try and runs like a scalded dog for 5 minutes then slowly cuts off like when they run out of gas. Prime again and runs great for another few minutes and repeat.
Odd thing is it ran for 20 or 30 solid minutes the other day while I was weeding a rough, steep drainage ditch area. Tilting up/down/sideways pretty much the whole time. Then moved back to the level yard and off it goes after a few minutes.
This has got to be a fairly simple problem. Anyone know what is going on?
oldstick is offline
post #15 of 34 (permalink) Old 05-19-2008, 08:38 PM
Top Dog
30yearTech's Avatar
Fuel pump diaphragm may not be pumping fuel into the pickup area, operating on an incline and fuel can make it's way to the pickup without the diaphragm pumping it there. Probably a new diaphragm in the carburetor will take care of the problem.
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
