Coleman Powermate 6250 Problem - HobbyTalk
Reply
post #1 of 20 (permalink) Old 02-21-2006, 08:00 PM Thread Starter
Member
I came across a great deal on a as is Coleman Powermate 6250 Generator. The engine runs well but I get no voltage. I took one of the covers off the generator head and a set of brushes are there. This seems to magnify the field when the motor turns so it will generate power. I put 12 volts DC to the terminals and I get 66.4 volts out of receptacle. I am guessing that this is the part thats not working correctly. Does anyone have a clue on how to repair? Or were I can get a parts manual for this generator?
Viper
Viper32 is offline
Sponsored Links
Advertisement
post #2 of 20 (permalink) Old 02-22-2006, 02:20 AM
Member
Assuming there isn't an open circuit, perhaps this will help: manual or troubleshooting guide.
There's a dropdown box to get parts lists for specific models on the site.
p.s. - p.7 "exciting the generator"
p.p.s - what's a great deal?
Stormy-In-FL is offline
post #3 of 20 (permalink) Old 02-22-2006, 05:44 AM Thread Starter
Member
Yes I did the exciting the field deal but I only get 66.4 volts, also I can only get that voltage if I leave the 12 volts attached. As soon as I take the 12 volts off I get not voltage at all. Any other ideas on what to try or were to look? I paid 50.00 dollars for the unit and it was ran once.
Mark
Viper32 is offline
post #4 of 20 (permalink) Old 02-22-2006, 10:09 AM
Member
Quote:
Mark
Since that's roughly 1/2 of what it should be maybe one of the poles has gone bad. Have you checked what is recc. in the troubleshooting guide, ie. the diodes, capacitor, etc?
Try giving the Coleman tech line a call. It's an 800#.
post #5 of 20 (permalink) Old 02-22-2006, 05:31 PM Thread Starter
Member
Well the coleman troubelshooting guy says its the capicitor. I do not have original receipt so I guess I will be on my own buying this. Anyone have a clue what this may cost and were I can get the part number? The Generator model number is PM0545008 and its not listed on Colemans website.
Mark
Viper32 is offline
post #6 of 20 (permalink) Old 02-23-2006, 02:23 AM
Member
Mark
Looks like about $9.50. My guess it's part# 0034819.01. You can confirm it with the Coleman guy. He can also email a parts list and manual in .pdf format. I bet your genny is pretty much the same as the other PM054500x models. Coleman seems to use the last few numbers to denote minor model variations or production for a specific retailer.
try 0034819.01 Capacitor or your local Coleman PM authorized repair center. You could probably even use a cap. with the same values from an electronics supply place.
Also check w/ Coleman if they would honor the warranty based on the serial number. I would guess it's way less than two years old.
Out of curiosity. Does this have a Briggs model 204412 engine?
HTH
post #7 of 20 (permalink) Old 08-18-2008, 10:43 AM
New Member
I have a Coleman Powermate 6250 that will not start. I have gas, oil,etc.
I have used this for three years and it has been good to me. I wss told to CUT the oil Sensor Switch wire to determine if this is the issue. Which wire??
Bob
Bobjmorgan is offline
post #8 of 20 (permalink) Old 08-18-2008, 04:37 PM
Top Dog
30yearTech's Avatar
I would not cut any wires, remove the spark plug and check for spark. If you have no spark, then unplug the kill switch wire from the ignition module and retest for spark.
30yearTech is offline
post #9 of 20 (permalink) Old 08-20-2008, 06:23 PM
Member
Bob
I have the same problem and I bi-passed the oil sensor switch and it works great, if you follow the white wire from the on/off switch it goes to a square box (that is the sensor switch) on the other side of the sensor the wire is black,that goes into the motor. I cut out the switch wired the blk and white wire together,,works great,,,I want to replace the switch but I can't find it anywhere , I don't have the manual to get part number,,,,mine is about 3 years old as well,sensor must last 3 years,,,,
bear38 is offline
post #10 of 20 (permalink) Old 08-20-2008, 07:13 PM
Elder Statesman
get the sensor replaced, they are there for a reason you know!
pyro_maniac69 is offline
post #11 of 20 (permalink) Old 08-20-2008, 07:34 PM
Top Dog
30yearTech's Avatar
Quote:
Before you start cutting and bypassing switches you need to troubleshoot your issue and figure out what the problem is. While taking a shotgun approach may work sometimes, the smart way is to determine the problem and then fix the problem, otherwise you are just spinning your wheels!
post #12 of 20 (permalink) Old 08-20-2008, 07:49 PM
Member
I did troble shoot , i had no spark at the spark plug , first i tryed the wired pass the rocker switch, still no spark , wired pass sensor,,and I spark at the spark plug, then I cut out the sensor,,,this is why i'm here . i'm trying to get the sensor,,,it has 2 numbers on it 698366,D804...but i can't find it anywhere,,,this just happened,,,I will check the oil before starting, I just changed the oil and filled,but i want the sensor put back in....i found the manual online but the sensor is not listed in the part list. Can someone help me out, to find the psensor,,I agree parts are there for a resson, I should of explained myself better,,,,
bear38 is offline
post #13 of 20 (permalink) Old 08-21-2008, 12:13 AM
Member
newz7151 is offline
post #14 of 20 (permalink) Old 08-21-2008, 09:10 AM
Top Dog
30yearTech's Avatar
Duh...
I am not talking about you, you already cut your wires!
I was referring to Bobjmorgan, who is trying to find out why his generator won't start. Maybe its the oil switch, maybe its something else.... WE DON'T KNOW YET!
post #15 of 20 (permalink) Old 08-21-2008, 05:10 PM
Member
Calm down,,,gees . it's not that hard to put the wires back together,,,, anyway,,,if you need a new oil sensor switch powermate is not the place to look ,,,Powermate is nolonger in business....newz7151 you are correct you have to go with the motor company,,,mine has a briggs&Statton motor ,so have to do search or find a briggs&statton dealer,,not a powermate dealer. I should be able to find one !!! Thxs for help
bear38 is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
